Maximus VIII Extreme Onboard WiFi Issue
PeterMV
Hi All,
I have recently built a new system using the Maximus VIII Extreme and have recently begun to experience some problems with the onboard wifi adapter. It will be working fine before I go to sleep, but when I come back to it in the morning it has disconnected and I cannot reconnect until I disable then enable it from the device manager. Trying to open up the adapter settings from Network and Sharing Center does not work, and sometimes I have to reboot the PC in order for it to work again.
I have made sure that the PC is not turning off the power in both the power settings, and the device properties.
The one thing I noticed is that even though the latest wifi drivers for this board on the ASUS website are marked as being from 9/11/2015, the date on the driver I have installed is from 2014.
Anyone else having a WiFi issue?
Thanks for any help.
Peter
0 REPLIES 0
