06-26-2016
08:20 AM
- last edited on
03-06-2024
02:07 AM
by
ROGBot
06-26-2016 09:41 AM
Minsekt wrote:
you can select gen3 for pcie in bios. then it should run at max
06-26-2016 09:43 AM
brkkab123 wrote:
It could be a issue with the Nvidia driver's. They've all had bug's for a few months lately.
06-26-2016 10:00 AM
06-26-2016 10:12 AM
06-26-2016 01:13 PM
Nate152 wrote:
Hi reflex78
I wonder if it could be a faulty 980 Ti since you gtx 780 Ti and gt440 work perfectly fine.
Is there any way you can test the 980 Ti in another pc?
06-26-2016 06:37 PM
06-28-2016 12:17 AM
hiong wrote:
a handful of people experiencing a similar issue does not negate the thousands of others who do not face the same problem. your conclusion that there is a bug with all Asus motherboards is flawed. try this, take your 980 Ti out, give the PCIe contacts a good rub with an eraser or something, and try again.
