Lcd TV displaying issue when ram modules working over 2600mhz
ctorbaoglu
I have [Ripjaws V] F4-3600C17D-8GVK. I had strange problem. I will be glad if you help me.
My PC connected to a 32” LCD TV and resolution is fine at 1920x1080 while ram modules working under 2600mhz.
When I raise the speed above 2600mhz. The screen goes dark 2-5 seconds and comes back randomly or somethimes goes black at all. It comes back after remove and reconnect the cord. Drop down resolution to 1280x720 or changing refresh rate did not help either.
The LCD TV connected via HDMI. Please find my PC specs below.
Thank you
MB: Asus Maximuss VIII Hero
CPU: I7-6700K
RAM: G.skill Rşpjaws V- F4-3600C17D-8GVK
System Disk: Samsung MZHPV256HDGL M.2 Drive
Storage Disks: WD Black 4TB + Toshiba 5TB
LCD TV Telefunken 32XT-350i
OS: Windows 10 Pro
Asus Z690 Hero
G.Skill 32 GB 6400mhz
Samsung 990 Pro
MSI RX 7900XTX
Thanlk you for reply.
Which settings do you think that I need to tweak for get rid of lcd tv resolution problem?
Thanks
Asus Z690 Hero
Samsung 990 Pro
MSI RX 7900XTX
