IOAPIC 24-119 Entries - What is it and what kind of benefit is there
freddii
This setting is available in the BIOS which you can enable (default) or disable.
I am unable to find much useful information about this feature. It is not mentioned in the manual.
I disabled the feature because I simply does not know what it does. My computer seems to run fine, but not knowing what this does or when I need it bothers me.
wiki.osdev.org/IOAPIC
The Intel I/O Advanced Programmable Interrupt Controller is used to distribute external interrupts in a more advanced manner than that of the standard 8259 PIC. With the I/O APIC, interrupts can be distributed to physical or logical (clusters) of processors and can be prioritized. Each I/O APIC typically handles 24 external interrupts.
5 REPLIES 5
I-Siamak-I
I am also interested to know this.
+1 please
AKBAAR
its just makes more irq for windows to communicate through. it would be more useful if u enable MSI mode for that IRQ using this utility
http://forums.guru3d.com/showthread.php?t=378044
Thanks! So its recommended to set this option enabled?
YES it reduces latency communication between GPU and pci slots . very recommended
