So as you can see from the last couple of days, I've been beating my head down trying to figure out why my system has been crashing.
You wont believe what I found ->
Yup you guessed it, the PCIe express 'clip' came off the motherboard while I was removing the grafx card. It seems as if the piece that holds the plastic piece to the motherboard came out of the plastic piece that I can see. I'm VERY careful when removing cards and after all these years of building PCs this is a first for me. Called Newegg, yeah out of the 30 day warrenty. Called Asus, yeah their repair department will determine if its operator error or manufacture. If they determine my fault, then its the cost of a new MB for them to replace the orginal >.< ... WOW talk about charlie brown luck! Oh and did I mention this is the 2nd Alpha MB that has gone bad on me in the last 90days!!!! Glad I spend all the $$$ on this build ...
Asus ROG G751JY
