[HELP] CPU INPUT VOLTAGE HIGH AND Spikes to exactly 4.080V every so often.....
Daytrader
Level 12
Have this exact problem but on my ranger viii mb, any help please, https://rog.asus.com/forum/showthread.php?70838-HELP-CPU-Input-Voltage-High-and-Stuck-at-4-080V-RED-... , i just replied to that thread for help also.
Reply i posted to that thread below.
I have this exact same problem, found out when my pc would not start, and said overclock failed, ai suite shows cpu input voltage 4.080(guess that stops pc from booting), have a ranger viii, 6700k, once back to desktop thou, it runs all day while gaming with no problems, tried all the fixes in this thread and no joy, i am wondering did the original poster find out the problem, or did asus say if it was a problem with the motherboard ?
Nate152
Hi Daytrader
He never replied back but Asus support told him to RMA, I'd suggest contacting them and see if they recommend you do the same.
Daytrader
Level 12
Thx for reply, i really dont want to return mb, as once i reboot it works perfectly like it has for almost the last year, just each morning boot stops, so i go into bios and then restart and it works again.
