GTX 970 problems with Hero VIII
Wohoo
I switched my Motherboard Hero VIII processor I7-6700K and memory to Kingsto Savage DDR4 8GB(kit) and I started having strange issues with my GPU.
Overwatch crashes when I launch (sometimes my GPU goes from 50c to 80c when I launch the game) and Path of exile hud started going weird https://gyazo.com/24fb6b987fbde2bcc01c53221901fa7d , https://gyazo.com/d84c64cb03f824355668f07095a2e3af
and Java based OSRS client says "Failed to create the Java Virtual Machine: LoadLibrary2 failed - 126". I don´t know why but Arma 3 works fine but when I play rust my GPU temperatures goes to 70-80c
specs: http://valid.x86.fr/d4b974
old specs: Asus M5A99FX PRO R2.0, AMD FX-8350, Kingston 8GB DDR3
12 REPLIES 12
Nate152
Hi Wohoo
Welcome to the ROG forum.
Those temps are acceptable for a gpu as long as its not throttling. If you're using GPU Tweak, MSI Afterburner or EVGA Precision X you can set a more aggressive fan curve or set the fan to 100%.
Have you updated to the latest driver and are you overclocking your gtx 970?
Can you test with your previous memory?
Hey my fan was 100% when I launched Overwatch and played Rust because temperature was claiming. Im not overclocking it and yes I have updated drivers.
This is my second Maximus VIII motherboard, I sented first back for warranty because H1Z1 keep crashing for some reason and event viewer said ntdll.dll error and java said same as now so I thought something was wrong with the new parts since with my old parts games worked fine. I just tested with my old memory and it didi´t fit
Nate152
Ok was wondering if your old ram is ddr4.
Is the gpu usage (load) at 100% all the time, if you have more than a 60Hz monitor I would think it would be. You could try enabling v-sync at 60Hz and turn down any antialiasing to take some load off.
Arma 3 plays ok so this says your gpu should be fine.
Can you test with a couple more games and don't forget your specs. 🙂
Arron
When you changed the mobo did you perform a fresh install of windows?
My old specs and new specs are on the first post and I have only 100% gpu usage when I play rainbow 6, 60-70% when playing arma 3 and only 30-40 when playing CSGO or PoE. Dayz won´t launch either. I did not install fresh windows because it did not help me with a first time but I did just now install new windows and didn´t help me.
Nate152
Hmm yeah you always want to do a fresh install of windows when updating the motherboard as you'd have a different chipset driver and such especially if you're coming from a DDR3 system.
What psu do you have, I don't see it listed in your specs unless I overlooked it.
No its only thing that is not on the list, psu is XFX 650W XXX Edition 80+ Bronze Semi-Modular
Nate152
Is there any way you can test your 970 in another pc? If it tests ok then maybe take a look at the psu.
My GPU works fine with my old parts so I don´t think that is the reason. how large psu you think would work, I can get 550w from a friend to borrow
