Gene Hero POST CODE 55 - Gskill issue?
Ozy311
Topic Typo, didn't mean to put "Gene" in the topic. The MB is a Maximus VIII Hero".
My 6700K landed today to complete my build. Turning on the machine hangs at code 55 - Memory Not Installed. If I remove the Memory, I get the normal "Missing Memory beep" error 53. I have tried inserting the memory one stick at a time into DIMM_A2 and then tried pairs in DIMM_A2 DIMM_B2. No luck. I pressed MEM_OK, the system shut down and started back up with the yellow DRAM_LED light flashing, but it never completes.
I am using:
G.SKILL Ripjaws V Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4-25600) F4-3200C16Q-32GVK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231903
What am I missing here?
29 REPLIES 29
Menthol
Level 14
The Ripjaws are made for X99 motherboards, I could not get my GSkill 3000mhz CL15 kit to run over 2666, and were more stable at 2400mhz.
The Ripjaw V series are for Z-170 and X99 boards and will run at rated speed
Daytrader
Level 11
Here are the specs, would have thought they should work on hero viii as they start at 2166mhz, i cant even get into boot screen ?
http://www.gskill.com/en/product/f4-3000c15d-16grk
Series Ripjaws 4
Memory Type DDR4
Capacity 16GB (8GBx2)
Multi-Channel Kit Dual Channel Kit
Tested Speed 3000MHz
Tested Latency 15-15-15-35-2N
Tested Voltage 1.35v
Registered/Unbuffered Unbuffered
Error Checking Non-ECC
SPD Speed 2133MHz
SPD Voltage 1.20v
Fan lncluded No
height 40 mm / 1.58 inch
Warranty Limited Lifetime
Features Intel XMP 2.0 (Extreme Memory Profile) Ready
Daytrader
Level 11
Actually given me cpu post memory initialization error 32 now ? i have tried each memory stick in each slot, no joy, re seated the cpu cooler no change either, any ideals.
Hey I have had the exact same issues in the same order as you. Currently stuck on a 32 error. I found it works with 2 sticks with the 32 error but 4 doesnt work yet. Let me know if you figure anything out.
My specs
Specs
Maximus Viii
4x8gb Kingston Hyper X Fury BK 2666mhz (Only two 8gb works at a time)
Intel Core i7 6700k 4.00ghz
EVGA GTX980
850w Cooler MAster Silent Pro
I also have a cooler master H100i CPU cooler installed.
I just put my PC together a few days ago with the following parts.
CPU: Intel Core i7 6700k
CPU Cooler: Corsair H110i GTX
Motherboard: Maximus VIII Hero
Memory: G.Skill Ripjaws V 32GB DDR4-2400 (a lot of us rocking 32GB kits)
Video Cards: 2x EVGA GeForce GTX 980 Ti FTW (Thought about 2 hybrids but didn't want to deal with 3 sets of hose)
Soundcard: Soundblaster Z Series (Who uses these besides me?)
PSU: EVGA SuperNOVA 1000 P2
Case: Corsair 750D Airflow Edition
Storage: Samsung 850 Evo 250GB, Samgsung 840 Evo 1TB, 2x Seagate Desktop HDD.15 4TB in Raid 1
I didn't have any memory problems with mine so I guess maybe the Maximus boards are a bit more sensitive when it comes to memory?
H100i is a Corsair btw
My specs
Specs
Maximus Viii
EVGA GTX980
H100i is Corsair btw
Daytrader
Level 11
Just checked and this ram is compatable memory DDR4 3000 Qualified Vendors List = http://webcache.googleusercontent.com/search?q=cache:uQUeMnh5RqwJ:dlcdnet.asus.com/pub/ASUS/mb/LGA11...
Daytrader
Level 11
I have ordered some Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black (CMK16GX4M2B3000C15), now that should be compatable i hope, lets hope it was the ram that was the problem.
Daytrader
Level 11
Glad you got yours fixed, wonder how tighten cooler to much actually causes the error 55 memory not installed, i mean whats cooler tightness got to do with memory anyway ?
