Flash Video Doesn't work when Sonic Studio is running in the background.
BStoltman
Basically exactly what the title states. If I have Sonic Studio running in the background. If I watch flash based video online, the flash plugin will crash. However if I kill that app and refresh everything works fine. Is this a know bug, or is there a way to fix this.
Thank,
BStoltman
PS, My Computer Specs are as follows:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler
Motherboard: Asus MAXIMUS VIII EXTREME EATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 32GB (2 x 16GB) DDR4-2666 Memory
Video Card: Asus GeForce GTX 980 Ti 6GB STRIX Video Card
Case: Inwin 707 BLACK ATX Full Tower Case
Power Supply: Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer
Operating System: Microsoft Windows 10 Pro OEM (64-bit)
6 REPLIES 6
Oops sorry should have mentioned that. I am using Firefox!
I had a similar problem...I discovered that I had to disable hardware acceleration for the flash videos.
https://www.macromedia.com/support/documentation/en/flashplayer/help/help01.html
You need to open an HTML 5 flash video and then disable the hardware acceleration with a right click menu and then open the regular flash.
https://helpx.adobe.com/flash-player.html
I have noticed the same thing. I have the Asus Maximums VIII Hero.
Flash crashes in Firefox (FF) when Sonic Studio runs. Also when Sonic Studio is running Windows Live Mail (WLM) doesn't run smoothly/the animations lag and the UI generally is not very responding.
You can try to bypass the problems by disabling the automatic start of Sonic Studio. In my opinion this is a better solution than disabling hardware acceleration. Though it should be looked into how sth. like Sonic Studio can produce problems with an email program.
Raja
May want to make sure you are running the latest Sonic Studio/audio drivers.
