fan card
morpwr
Does anyone have any idea where you can find a fan extension card? It seems these are impossible to find. The only place I have found one was on ebay and its in Germany.:mad:
4 REPLIES 4
Nate152
Nate152 wrote:
Hi morpwwr
Welcome to the ROG forum.
E-bay may be the only place to get it, I see them at newegg but it's out of stock.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813995054&cm_re=asus_fan_extension-_-13-995-05...
Thanks. It looks like there is a lot of really good help and information here. I did finally find the extension card at micro center and they had a bunch of them. But I appreciate the help.
JustinThyme
My extension card that I'm not using came with my Maximus VIII Extreme/Assembly.*
Not even using it. *
So does that mean you want to get rid of it?
