02-05-2016 07:51 PM - last edited on 03-05-2024 10:41 PM by ROGBot
02-09-2016 10:09 PM
lolwtf wrote:
My boot time is 23 seconds...
I do not know why.
I have Win 10 pro Uefi on M.2 ssd, 2 hdd in raid, an other ssd and an other hdd. (Raid rom loaded at boot time)
No, i don't have other keyboard.
02-10-2016 01:11 AM
02-10-2016 03:12 AM
fromthewatt wrote:
can we request a asus rep forward this issue to asus so that a fix be added to next bios update ?
surely they can get hold of a corsair rgb k70 kb and cm quickfire and see it gives issue on cold start
02-10-2016 06:08 AM
eicalos wrote:
I purchase Belkin USB HUB from the online shop. I receive it just now. I try to simple test turn off pc completely (Enable S5 in BIOS). Some user in corsair forum posted it can fix by using usb hub, i try to purchase usb hub to test.
turn off extension socket that connect with monitor, pc and usb hub external source. It seem like can solve this issue.
It can extrapolate this issue must cause from Asus UEFI surely that topic on USB Protcol (USB Handshaking and timer).
** Okay after I test 10 times for this solution.
- Shut down my pc
- Switch off extension socket that connect with monitor, pc and usb hub external source.
- Wait 5 minutes
- Turn on my pc
I found when i connect keyboard with usb hub full connection (usb+external power) it's working ok, don't have
any problem and connect only usb port ot pc. It has a problem. The other brand may be manage better than
Asus UEFI firmware.
My hypothesis focuses on usb power current draw to keyboard mechanical keyboard alway has more power
consumption than normal keyboard. This issue concern usb management control on motherboard.
I will conclude this issue as soon as possible. In Tomorrow i will test this solution again when i get up on the morning.
02-10-2016 06:27 AM
fromthewatt wrote:
k70 rgb have 2 methods of connecting to pc, u must connect both kb usb ports if using usb 2, if using usb 3, u must connct only the 1 kb usb cable to usb 3 port.
i tried both methods, same issue.
02-10-2016 08:01 AM
eicalos wrote:
Do you test with usb hub?
02-10-2016 08:18 AM
fromthewatt wrote:
dont have usb hub, can u post link to description ?
02-11-2016 12:50 AM
02-11-2016 01:26 AM
fromthewatt wrote:
can u explain your interim solution i dont understand.
also i must mention : my original bios was 0508 dated 08/10/15 wich did not give this issue
my issue started after i updated to bios 1402
