02-05-2016
07:51 PM
- last edited on
03-05-2024
10:41 PM
by
ROGBot
02-09-2016 06:03 AM
02-09-2016 06:16 AM
fromthewatt wrote:
i had same issue, but i had a usb drive in usb 2 port aswell,
i then removed the usb drive, i also disabled AS Media usb in bios ,
it now detects my kb, i have corsair rgb k70 kb.
mobo bios 1402 😉
02-09-2016 06:22 AM
eicalos wrote:
Can it fix first boot (No Keyboard Detected)?
I try to disable AS media too, but it don't work. (AS media control usb 3.1 may not concern USB 2.0/3.0)
Now i find the only way to fix it. Unplug usb port and plug it again.
02-09-2016 06:29 AM
02-09-2016 06:43 AM
fromthewatt wrote:
so i have double checked now,
when kb is detected in windows by removing usb cable, insert usb cable, and quickly power off pc, quickly power on pc, it detects.
when pc is powerd off completely and psu cable removed ( until mobo power led light goes off ) and power on pc, kb does not detect.
so as long as there is power to mobo even when pc is off,( psu cable is plugged in or psu power button is on) kb will detect.
but as soon as mobo has no power from psu( psu cable removed or psu power button is off) kb is not detected.
it means that bios does not store kb detect setting from cold start....
02-09-2016 06:50 AM
eicalos wrote:
Yes, sir i tested these way same as you. This problem will from UEFI firmware surely.
I try to test on the others brand Gigabyte/MSI/Asrock , these mainboards don't have this problem.
Yesterday i contact to Asus team support. They say this problem can't handle on responsible of Asus, the keyboard manufacturer should be fix on them product Dammit i'm so angry Asus unworthy ROG(Republic of Gamer).
Asus don't care feeling of customer.
02-09-2016 06:59 AM
fromthewatt wrote:
if my corsiar rgb k70 gives same issue, i dont think its a kb manufacturer issue.but i will see if i can update my kb firmware now, then test again, if there is a firmware update for my kb
02-09-2016 06:17 AM
02-09-2016 07:14 AM
eicalos wrote:
Oh! lolwtf
I try these configuration on my Maximus VIII Hero (firmware 1402).
It's not work when i turn on my pc (1st boot). It shows "No keyboard detected".
In your apm configuration, what' value of ErP ready do you set?
02-09-2016 07:32 AM
lolwtf wrote:
My board is Maximus VIII Gene with 1402 bios.
ErP ready DISABLED
Power on by ... All DISABLED
With this setting on my pc keyboard work fine, no problem.
When i swith off my pc i disconnect alway the PSU cable.
