Bluetooth audio problem, Undescribed cable
basanova
Hello Just got this M/B and satisfied with its design and performance but have couple of questions.
All driver installed right, I don't see anything wrong with the system build.
I'm using Windows 10 and Edge web browser.
1. I'm using on-board sound.
When I connect it to my bluetooth speaker, it cuts sound often.
I play some music from youtube and when I open new tabs or do something this issue always happen.
2. Also, when I play Youtube, around 3~5 minutes, video always stop for 1~2 sec and plays again.
3. What is the cable below for? Where I have to connect it?
53416
DamianStr
Hello
Did you also try to play a video from youtube with Chrome or Other browser and Are you sure your internet speed is fast enough
and that cable is a temp sensor you can plug it in on the Extern fan card or onboard
