03-21-2016
04:36 AM
- last edited on
03-06-2024
02:03 AM
by
ROGBot
04-10-2016 11:12 AM
07-04-2016 01:24 AM
07-04-2016 07:23 AM
davidpiot1974 wrote:
I am having the same problem with my Asus Formula VIII
Shutdown issue: Windows 10 does trigger the shutdown process, the monitor goes black but fans won't turn off (not normal) and MB LED's stay powered on (that is normal)
No complete system shutdown MB. have to shut the PSU down manualy for complete shutdown.
I know it is not an PSU issue because it worked perfect on my older MB.
Is this a Hardware failure of the Asus MB?
The "funny" thing is, sometimes the pc does shutdown correctly, but it does that very rarely and i do not know the conditions why it does that.
I looked at every setting in the BIOS and could not find anything.
I even did a complete BIOS flash yesterday, but to no avail.
Please advise. I can find a lot of people with this problem. But i still have to find (read) the solution.
According to the ROG forum this is a known issue?? any Solution?
could this be a hardware problem of the MB and if so would a new MB be the solution?
For a MB that costs over 300€ i would expact it to work.
07-05-2016 12:52 AM
Chino wrote:
List your complete system specifications for me please. Also indicate if you have the Intel RSTe software or AI Suite 3 installed.
07-07-2016 11:12 PM
07-10-2016 11:57 PM
07-04-2016 07:05 AM
sucka wrote:
Hey i had crackling and when sound were played pc almost locked, took forever even for a click right menu to open.
this was on m8 extreme and using strix raid dlx audio, after looking into it, it turned out the audio as i knew it was using usb through pcie, that it has asmedia usb hub, and after installing the latest asmedia driver from the motherboard(even though i have all asmedia usb disabled) everything runs fine now, so it was a problem at least on this board and audio with the drivers, wanted asmedia driver and not microsoft default.
