Hi Everyon. I have strange problem with ASUS Maximus RANGER Z170. Could you help me?
Sorry for my english
My new spec PC
Asus ranger
MSI gtx 1070 Armor OC
ram 2 x 8GB Corsair (QVL list compatible)
When i boot my pc after first one beep there is 1 long and 4 short beeps and d6 error has occured but everything is extremely ok.
Windows start. System stable. Now listen...
1. When the cable DP is connect to monitor and before boot pc monitor is "on" the d6 problem doesnt exist on the DVI cable everything is ok
2. When the cable DP is connect to monitor and before boot pc monitor is "off" the d6 problem exist on the dvi cable everything is ok
3. When i changed CSM to disabled the "d6" problem has occured on the DP cable even with only IGPU card and if the cable is do not connect to pc
When CSM is enabled d6 not exist on all cable no matter if they are connect or not connect to monitor even if monitor on or off 🙂
I checked everything, slot contamination, pin bent, different slot ram
Bios is newest 1701
IS this normal or mainboard faulty. Please help
