09-05-2015
09:35 PM
- last edited on
03-06-2024
01:32 AM
by
ROGBot
09-06-2015 06:14 AM
09-07-2015 12:32 AM
Menthol wrote:
The Q code does not show temps, AO is the correct code at a successful boot to OS.
Personally I would return the RAM for some GSKill Ripjaw V series but if you know what chips are on your your set of RAM, my guess is the older Samsung chips designed for the X99 chipset, you can go to the memory section of the bios, memory presets and look for 4x4GB single sided older Samsung and enter one of the presets which will enter correct values for all the timings on your board. This may or may not help, you would have a lot less headaches purchasing memory designed specifically for the Z-170 chipset
09-06-2015 03:38 PM
09-10-2015 01:25 AM
11-23-2015 12:29 PM
jbhowlesr wrote:
So I got the g skill ram and it solved some of the problems but caused other, namely code 55 and still had anti-surge. I finally gave up and returned the hero board today and gave the MSI Gaming M7 board a try. As it turns out, that solved all the problems. It tells me that Asus didn't produce a very quality product in the z170 line since I have the same issue across two boards; Z170-AR and MAXIMIS VIII Hero. I fee confident in stating that if anyone else is experiencing the same issues, that the problem is likely a product poorly produced by an otherwise reputable company such as ASUS.
11-23-2015 02:40 PM
11-24-2015 06:38 PM
Chino wrote:
And which M.2 SSD are you using?
11-24-2015 12:35 AM
11-24-2015 07:46 PM
