Wake On Lan problem
Kriminal73
Hi to all,
I'm trying to enable the WOL function without any success.
On bios I've disabled the fast boot, enabled the Power On By PCI-E/PCI and enabled the magic packet on Windows 10 Ethernet properties, but still cannot turn on the computer with WOL.
Any suggestion?
Kriminal
Μobo:ASUS RAMPAGE V EXTREME bios 3301-CPU:INTEL I7 5960X-Cooler:Noctua NHD15-RAM:HyperX Predator CL15 4x4GB6-GPU:ASUS STRIX GTX 1080 OC-PSU ANTEC 1200W dual power supply-SSD Crucial M550 512 GB (boot with Win 10 Pro)-HDD 4x2TB Seagate Raid 10+2x1TB Raid 0- Case Antec P190
sergio77
Kriminal73 wrote:
Hi to all,
Any suggestion?
Kriminal
Μobo:ASUS RAMPAGE V EXTREME bios 3301-CPU:INTEL I7 5960X-Cooler:Noctua NHD15-RAM:HyperX Predator CL15 4x4GB6-GPU:ASUS STRIX GTX 1080 OC-PSU ANTEC 1200W dual power supply-SSD Crucial M550 512 GB (boot with Win 10)-HDD 4x2TB Seagate Raid 10+2x1TB Raid 0- Case Antec P190
Try these steps in this order:
1. Install newest LAN driver;
2. Disable or Enable the ERP (S4-S5) in UEFI;
3. Turn Off Fast Startup in Windows 10 (power options).
4. NIC driver settings: Enable "Allow the computer to turn off this device to save power", Enable "Allow this device to wake the computer", Diable "Allow the computer to turn off this device to save power"
After each single step please reboot OS, and try WOL function.
Intel Core i9-13900KS @ 6.2GHz / ROG Ryujin II / Asus ROG Maximus Z790 Hero / G Skill Trident Z5 64GB DDR5
Asus ROG Strix GeForce RTX 4090 / Asus ROG Swift PG43U
Samsung 990 Pro NVMe 4TB / Samsung 850 Pro RAID 0 2TB
Asus ROG Thor 1200W Platinum / ROG Strix Helios
