10-07-2016 03:31 AM - last edited on 03-06-2024 01:39 AM by ROGBot
10-07-2016 01:17 PM
skypine27 wrote:
I recently swapped from a "normal" R5E to the V10 and the new Fan Expert (Version 4 now, not Version 3 like on the R5E) isn't working too well anymore.
Often when I reboot, the Fan Expert says "CPU fan has changed you need to re run auto tuning..." even though of course I have not changed the fans connected to the CPU header.
Also, how are the headers linked with respect to RPM control? I would guess, that like on the normal R5E, the CPU_OPT header is "slaved" to the CPU header. But what about the High_AMP and the Water_Pump? Are these slaved to each other? And what about the EXT_ plug? Its it independent ?
Thx for any info
10-07-2016 09:37 PM
10-08-2016 03:44 AM
10-09-2016 04:47 AM
skypine27 wrote:
I might nuke the entire Asus AI Suite package and try to set their RPM in the BIOS like Danny mentioned. Is there anything "useful" in the AI suite package I'd be missing out on if I dont install it? I cant think of anything I use off hand, except Fan Expert?
10-08-2016 06:45 PM
