USB-C with a Displayport Alternate Mode on R5E
Semireject
Hey guys,
I got a Wacom Cintiq Pro 16 tablet and to get it running with 4k natively it needs to hooked directly USB-C (with DP alt mode). And since I have a Rampage 5 Extreme I dont have that and have to run ut through the Wacom Link adapter with DP and USB-A which doesn't support full resolution (only 1440p).
So my question is that if you know any PCI-E cards that support USB-C with Displayport Alternate Mode? Can I get that with the Asus ThunderboltEX card for example?
I know there's some tricks to get this working with the adapter which involves a short dp 1.2 cable, but that unfortunately not an option for me at the moment. And despite that its worth a lot to not use tha adapter.
0 REPLIES 0
