UEFI 1801 for RVE10 and Strix X99 issues
Nixon2992
Who install this version BIOS can you write bugs and featured you found on it?
46 REPLIES 46
Arne Saknussemm wrote:
I do not know what the Logitech thing means...but I use a logitech keyboard and mouse and they both worked fine before and after 1801...so unless you actually have a problem with it I would say you don't need to update at all.
I just don't understand the performance difference you are seeing...and can't think of something that could cause that much of a difference!
😮 heh...the intel OC...just for validation...quick overclock on very cold water...
Have you run AIDA at stock...no OC...on 1701 and 1801...?
Yes i tried at xmp 2400, same drop in performance ☹️
I don’ Know what’s the issue, very weird, anyway thx for your support, i will stay in 1701*
Arne_Saknussemm
Level 40
Nah...sorry it's not solved...but yeah stay on 1701 for now...the pragmatic thing to do...
I suppose you went through BIOS RAM settings looking for differences?...I just don't know...you try adding a bit more cache voltage on 1801?
tried reset all my oc to default nothing helped.
I hate to have an issue without knowing the cause.
Anyway i am now on 1701 bios.*
Thx again, you are the only one that tried to help me*
Yeah I know what you mean!
Have you tried checking CPUz when on 1801 to check all 4 DIMMs are up and running?
Have you tried giving them a bit more voltage? VDIMM or VCCSA...might be the OC settings on 1701 are not quite enough on 1801? Though if stock is affected equally :confused:
Sometimes updating BIOS is definitively not worth it!
i give up.
Running 1701 without issue.*
Koutport
Nothing at all with my RVE10 and today I reinstall AI suite 3 and I run AI3Cleaner after reboot everything Ok with the version 1.05.13 too!!
Μobo:ROG MAXIMUS Z790 FORMULA-CPU:Intel Core i9-14900K-Cooler:EKW-EK-KIT RGB 360-RAM:G.SKILL Trident Z5 DDR5-6400 CL32 64GB(4 x 16 GB)-GPU:ASUS GeForce® ASUS ROG STRIX GAMING RTX-3080Ti-#43; EKW-EK-KIT 480 RGB -PSU:Corsair HX1200i:HDD:Samsung 990 PRO 2TB+Samsung 990 PRO 2 TB RAID-0 +- Case:Thermaltake View 91 Tempered Glass RGB Editionx monitor:ROG Swift PG32UQ
Arne_Saknussemm
Level 40
