UEFI 1801 for RVE10 and Strix X99 issues
Nixon2992
Who install this version BIOS can you write bugs and featured you found on it?
46 REPLIES 46
Installed on my X99 and no probs so far
Darkest
Updated from 1701 to 1801.
When "Advanced" => "Onboard Devices Configuration" => RGB LED option "In sleep, hibernate and soft off states" is set to "Off" system does not start. Screen is black, QCode stucks at "bF" and after a while PC turns down itself. Only BIOS reset helps to bring it back to life.
What frequncy you RAM sticks?
BF post code indiacte issues with ram/imc undevoltage.
I have four Kingston HyperX Fury Black 4GB/2666 (HX426C15FB/4)
Chino wrote:
Is it a single memory kit?
It is four sticks of the same model each one in individual package, not a 4 in 1.
You system boot normaly if speed ram sticks is 2133Mhz?
Combining memory kits and modules is always a bad idea. Try removing your memory modules except for one to test.
