Strange random no post
stumpy6317
Guys and Gals i come here for some help with a very strange post issue. I had this problem for about 4 months now.
The problem is during the post sequence i get a error code of b1 or it could be 61.
Then if i press the reset button instantly it stops at 79.
But if i reset the bios. Set everything back to how it was before. I have NO OVERCLOCK. I just setting the XMP profile, change ram voltage to 1.350. Turn fans to PWM. Turn off onboard sound, wifi, blue tooth.
This issue is very, very random. I can go weeks without it happening, but at some point in the future it will again.
This is my 4th replacement board. I have been problem free with this one otherwise for 9 months.
So hopefully there is someone that can help me solve this.
Thanks for any help you may give.
jrmcdou
Try not using XMP. XMP gave me nothing but problems. When I set it manually it was fine. XMP was making my settings too agressive with the voltages. It would work for a while and then get unstable. You may want to run Memtest86 and Intel diagnostic tool after entering all settings manually to make sure it is stable. After that if the memory and the processor tests good you can run Aida 64 for 3 - 4 hours and make sure it's all stable together. That's just from my experience with this issue that worked. Someone else may have other advice.
