11-06-2016
09:44 AM
- last edited on
03-06-2024
01:32 AM
by
ROGBot
11-06-2016 11:59 AM
11-06-2016 01:42 PM
thebski wrote:
Hey guys, I'm trying to set up an OC on a system I put together yesterday with a 6900K, RVE10, and 32 GB of the Dom Platinum SE memory. For some reason, it doesn't matter what number I enter in the adaptive voltage box, it uses 1.268V. In order to deviate from that number I must use an offset. Changing the voltage entered in the adaptive voltage box changes nothing in the OS. It doesn't make any sense, and I never had this problem with my X99 Deluxe and 5820K. Any ideas?
11-06-2016 01:50 PM
Brighttail wrote:
Just outta curiosity, which BIOS version are you on? I couldn't get the Corsair Dominator SE to work on 1003 without really upping the DRAM voltage. Works perfectly at 1.35v on 901.
11-06-2016 01:49 PM
11-07-2016 07:41 AM
thebski wrote:
I am struggling with the Realbench Stress Test. It seems I can't even get through it at default settings. For some reason the motherboard defaults to 4 GHz at 1.268V. I'm not sure how I make it run real default settings of 3.2 or whatever is on the box. At any rate, even with default settings in the bios (4 GHz), the stress test either crashes Lux Mark or BSODs out before I get to 30 minutes.
In Rajas guide for BW-E he said to do at least an hour stress test, but I can't seem to get through even at default. I can loop the benchmark without issue.
11-07-2016 11:24 AM
Chino wrote:
Is system at stock defaults?
