LLC does not interfere with vcore in H-E and B-E because of internal voltage regulator, it only affects input voltage.
If you wanna low down that vcore voltage (6950x), u got to decrease the selected one to 1.30v more or less, so that the regulator has a lower point. But you will have to check if it is enough for the desired frequency.
The best program under OS to check the vcore voltage is Aida64, not CPU-Z which only shows VID selection.
Asus x670e Hero, 7950x, TG 7000, Master 4090, 970 PRO, 860 EVO, Intel 750,
SN850, SN750, 840 Pro, 2xSkyhawk 4TB, Pioneer S12U
EVGA T2 1600, Silverstone TJ11, Custom LC, Acer Predator x35, Philips OLED
