Rampage x99 Offset mode? Where is it?
Brighttail
Level 11
Hey all,
I wanted to experiment with offset mode voltages. In the past I could change the CPU Voltage to adaptive or offset mode. In the newer BIOS, I'm not seeing this option.
I see an area where i can change some offset values from - to + and the numerical value is between 0 and 20... I"m used to setting it by a value of ".320" as an example.
So what am I missing? Is there an offset mode in the new x99 BIOS and if so, where/how do i turn it on?
Thanks,
BT
Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
Menthol
Level 14
Change fully manual mode to disabled, adaptive and offset will become available
