Rampage V Extreme
memetic
I can no longer boot. When I push the start button, the machine turns on and gives a Q Code "00" and does nothing else. After trying this many times, I left the machine unplugged for a few hours, and tried again; the machine started and ran through the Q Codes like normal, but then shut off, then back on and to the "00" again.
Eventually, I took the entire machine apart, cleaned everything, and put it back together again. Still, the same problem. Boots to Q Code "00" and hangs.
Please help me.
Thank you!
0 REPLIES 0
