Rampage V Extreme Temperature Sensor Error
nsfranklin
When I boot my pc I get a "MB temperature error". In the bios the motherboard is ice cold as 35C. Everything else is around 30-40C. Except T-Sensor 2 and T-Sensor 3. which record 127C and 82-110C respectively. However I don't actually have any T-Sensor installed and there is clearly no burning. Does anyone have any idea of a solution or is the motherboard dead? (I believe its just dead) I was unable to find anyone else with this error.
I have tried all the standard troubleshooting included updating/backdating to many different bios version all with the same result.
Edit 1: Marking the sensors as ignored doesn't change anything.
nsfranklin
FuryA
hi ns if you've reverted back to the previous BIOS and it sill nothing changing
You can contact the local retailer for help RMA service
