02-20-2017
03:52 PM
- last edited on
03-06-2024
08:49 PM
by
ROGBot
02-20-2017 06:33 PM
02-20-2017 07:34 PM
badmojout wrote:
I struggled with the same issue and finally resolved it by changing a single BIOS setting: Rampage Tweak. Change the setting to Mode 1. Not sure if you are running XMP/overclock which may require additional tweaks to CPU Input voltage, System Agent Voltage, etc. But I'd recommend going to stock on everything with the exception of turning on the XMP profile and then changing Rampage Tweak from Auto to Mode 1. If the wake from sleep issue is resolved, then you can go back to restoring your overclock settings.
Took me over 2 years to figure that one out...
03-02-2017 01:15 PM
nonverbal wrote:
Thanks badmojout. Never thought to adjust that setting. I made the change to Rampage Tweak and will report back. I appreciate your input.
03-02-2017 02:06 PM
03-03-2017 08:04 AM
12-14-2018 12:47 AM
12-14-2018 12:50 AM
12-14-2018 01:00 AM
12-14-2018 01:06 AM
