Hi Guys,
Recently did a new build with all new gear, and I'm a bit stumped at some of the issues I get sometimes...
Issue #1 Sometimes only half my ram is detected, windows says I have 16GB, whilst at the same time CPU-Z says I have 32GB, Bios also sometimes states 16GB.
Issue #2 When turning on(before post), it will turn itself off, then back on, and then repeat that once more, before succesfully loading up.
Hardware:
Rampage V Extreme
i7 5930k
GTX 980 x2
32GB Corsair Dominator Platinum 2888
NZXT Hale 90v2, 850 wats
2xSSD in Raid0 and a 3TB HDD
Noctua NH-D14
Only thing Id mention is the CPU Cooler is rather large, so large infact I couldn't attach the RAM coolers, also I couldn't use certain RAM slots
The only BIOS settings that have been set are the DRAM settings using XMP, everything else is default (didn't want to do anything crazy immediately)
If I could get a pointer in the right direction that would be greatly appreciated, im a bit skeptical at how stable this thing is...
Edit: Also OS is 8.1 Pro
