R5E10 I/O shield LED dimming/turning off
s_mpL3
Hello all,
I bought a Rampage V Edition 10 around February and from the beginning it seems to have some sort of issue with the I/O shield LED. Some times the LED is dim and some times the LED is off. If I touch it, when plugging in a USB or something, it moves slightly and usually starts working normally so I think the LED might have a loose connection. Is there anything I can do about it? Does anyone know if the LED has a connector somewhere under the I/O shield?
Kind Regards
Specs:
Intel i7 6850k
32GB DD4 3000Mhz
Samsung 960 Pro NVMe
Chino
Level 15
Thanks a lot Chino, I think it's ok now. I'll see if it does it again 🙂
