R5E + Corsair Vengenace 3200Mhz DDR4 issue [SOLVED]
RoGHD
Hi people.
I buy a new RAM Kit for my R5E and i have a big big problem.. The RAMs is not working perfectly with this motherboard...
The RAM is from the new Corsair Vengeance LED series. Link: CMU32GX4M4C3200C16R
The problem is simple, when i set the XMP profile the system is not boot, stop the process with 6F error: Picture
Yes i know the 6F error is the System Agent Voltage.. I increase this voltage but failed. No boot. Again and again 6F. (1.2V too)
So i try different methods for fixed this issue:
-Before/After BIOS Update = Failed.
-Increase DRAM voltage = Failed.
-Increase CPU voltages = Failed.
-Increase DRAM Timing = Failed.
-Increase VCCSA voltage = Failed.
-Increase VCCIO voltage = Failed.
-Manual set the XMP settings = Failed.
-Trying the black RAM slots = Failed.
-1 RAM module = Failed.
-2 RAM module = Failed.
-CPU OC = Failed.
-Mode 2 change to Mode 1 = Working! (But only 3000Mhz because this motherboard is a crap)
I tried everything fixing method I could find on the Internet but not working..
One thing is working.. when i RESET the BIOS and run all hardver with default (AUTO) settings. The RAM now is only 2133Mhz. But this is ridiculous.. I buy 3200Mhz DDR4 and running only 2133Mhz? LOL.
Sorry guys but this is the worst motherboard i ever see in my life... The motherboard's description is say: 8 x DIMM, Max. 64 GB, DDR4 3300(O.C.) /3000(O.C.) /2800(O.C.) /2666(O.C.) /2400(O.C.) /2133 MHz
So why not working my RAMs with 3200Mhz?
PC Specs:
R5E (Bios Version 3402)
i7 5930k @ 4.4Ghz
My old RAMs: HyperX 32GB (8x4) 3000Mhz CL15. (Working perfectly)
MSI GTX 1080 Gaming
Pls help or pls make a new BIOS for this RAMs. 😞
19 REPLIES 19
nick_the_greek_
all i was saying the the 125 strap does do 3000mhz but i choose not to run the 125 strap .it was a just test
Good news i find a working settings.
CPU 4.37Ghz + 125Mhz strap + 2666Mhz DDR4 16-18-18-35 1.36V + Mode 1.
This settings is not started with Mode 2...
Wtf is this Mode thing? I know the Mode 2 is for OC but the PC is started only Mode 1 with this settings.
This motherboard.. -.-'
New tested settings:
CPU 4.37Ghz + 125Mhz strap + 3000Mhz DDR4 15-17-17-36 1.36V + Mode 1.
Working fine! 😛
Btw, what is the safe Nort Bridge Voltage for 24/7?
And what Mhz?
Avenger411
Hello,
Had to sign in for this (took a pause from the forums). You say you're not a noob YET you quote asus' memory oc specs as if you were supposed to achieve them. You also proceed to blast a fellow forum member who was trying to help. I'll remember your name and next time i'll make sure not to help you with any of your troubles. Plus i just read again that you do not know what are the memory modes, and you say you're not a noob. I will not explain what these modes do and find it for yourself. In these forums, it is okay to be new to a product and to be lost in the bios etc, but acting like you did, lol.*
This post was a waste of time from the get go. It goes to show how disgusted i am by what you said to fellow member legolas.*
Max*
Cpu : Intel 5930K@4.25ghz@1.2v / Cache @4.25ghz@1.20v
Cpu Cooler : Corsair H100i
Case : Corsair 780T
Memory : G.Skills 32GB DDR4-3200mhz CAS 15-15-15-35-1T@1.370v
Motherboard : Asus Rampage V Extreme (BIOS 3504)
M2 : Samsung 950 Pro NVME 512gb (Gaming)
M2 : SSD1 : OCZ RD400A 128gb (windows)
SSD1 : Crucial MX100 512gb (data)
Gfx : EVGA Titan X w/ 980 Hybrid Cooling AiO Liquid Cooler
PSU : Antec HCP-1000W
Monitor : Asus RoG Swift
Ahhhahaahahahaha XDDDDDD
The full forum is a waste of time because your smart friends say idiot things.. not read my posts only say something bullsh.t for more post points.
Post hunters! And you are too.
IMC weak yeah... The motherboard is a big sh.t not my IMC... Ohh yeah and Sh.t BIOS... The previous BIOS is better than the new? WTF man?
And this motherboard for tuning tournaments? Ridiculous. Just ridiculous...
You remember my name? 😄
Its only 5 min and i have a new name, new config, new location, new IP. You are a very naive guy... XD
THX for all. Asus is the biggest sh.t in this year with the sh.it Strix cooler too.
In your PC Specs:
You use Win 7 + GTX Titan? What games are you played? DX9??? XD Idiot. Yes DX9 need Titan... SLI Titan XDDDDDDDD
Avenger411
Hello,
I am not a post hunter like you say. I have seeked help many times when the board originally came out and from what i've learned fron raja, praz and others, i've tried to pass it back to those in need. You have to understand that the X99 architecture introduced many electrical improvements along with new features to consumers. What goes on behind the post is far more complex than what you and i can think of. If your IMC is weak then too bad you're stuck with it. Also, changing bios for the sake of it is not wise. If all goes well on a bios don't change it or you can always experiment with the second bios chip. I cannot prevent you from changing your name but if you would do it, it would only imply that you acknowledge my arguments and that you do not stand by your own word, which isn't surprising. The problems asus encountered with the X99 platform are also present in other brands such as msi or evga. Not knowing how to setup your stuff doesn't mean asus is crap, it only means you're not taking the time to understand what's going on. Also, if you would've read my first post correctly you could've deducted that i haven't been here for a while hence my specs not updated. What you just did right now is exactly why you trashed another member.*
You are full of non sense.
This thread needs to be closed before more stupidity comes out of RoGHD
*Max*
Case : Corsair 780T
Sorry but no have time for reading some bullsh.t crying.
Btw i m not english so i dont understand what crying in your posts. XDDD
The google translator is going die when i paste your crying. XD
This is funny: Posts: 606
You devil. xDD
Yes the post is need to be closing because i don't find "smart" members who can help me...
You have money for good PC but no have money for brain my little friend. BB.
Avenger411
Hello,
English is not my primary language yet i find that it is quite sufficient for forum purposes. You say i have no brain yet you do not type/speak enligsh which is not only THE language but also one of the easiest to learn. Trying to insult people on their probable intelligence is a testomony to your non sense.
Max*
Case : Corsair 780T
Nooo you not a post hunter.. i see yes, you not. XDD
Repost more pls... XD
Btw you buy the new Sh.tPhone 7? 😄
Pls say you are an apple fan. XD
Praz
Thread closed.
