Problem with rampage v e 10 and ASUS ROG Swift PG279Q
afshin
dear
i have Ramage v e 10 motherboard and i have ASUS ROG Swift PG279Q , when i connected with display ports , sometimes motherboard does not boot !!! black screen is shown, then i have to rest my pc.
specially when i change or update motherboard bios this problem happend again.
but when i connected by hdmi nothing happend and it works fine.
may anyone help me to reduce this problem.
thanks
mainboard Rampage v e10
vga gigabyte 1080 extreme
lcd ASUS ROG Swift PG279Q
LiveOrDie
Level 11
This issue would more or less be related to your GPU not your motherboard.
Chino
Level 15
Make sure you're connecting the DP cable properly and the connector goes all the way into your GPU. Also try testing with another DP cable.
