Problem with disc/ssd 2.5" connected in USB3
tistou77
Hello
In addition to the problems of BSOD... I have a problem with USB3 ports of the case (connected with the header USB3 on the motherboard Rampage V Edition 10)
If I plug a disk/SSD 2.5" (in USB3), the disc appear / disappear / appear, etc ... instantaneously under Windows
No problem with USB3 drive, mobile phone, etc...
I had had the same problem with the Rampage V Extreme (bios 3xxx, no problem with bios 2xxx), and I put the PCH Core Voltage at 1.07v and the problem was solved
With R5E10, I have to put the the PCH Core Voltage at 1.10V and only a header on 2 works correctly (same problem with the other header)
From where the problem can come ?
May be the VCCIO PCH Voltage ?
Since the 3xxx bios on the R5E and with R5E10, it's not terrible voltage management
eg with R5E10, VCCIO CPU to 1.05V in the bios, applied 1.01v
Thanks
Sorry for my english 😄
Case: Lian Li A77F
MB: Rampage VI Extreme Encore
CPU: i9 10980XE
RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
GPU: EVGA RTX 2080ti XC Ultra
PSU: Seasonic Prime Ultra Titanium 1000W
OS: Intel Optane 905P PCIe
DATA: Samsung 980 Pro
SOUND: Asus Xonar Phoebus
0 REPLIES 0
