Offset voltage used with adaptive voltage
maddick
Are there any use-case scenarios for using both offset and adaptive voltages concurrently? I'm wondering when the delta between the baseline voltage and adaptive turbo voltage becomes a noticeable factor in your settings. I imagine that the climb from one end of the voltage spectrum to the other being lessened might provide better results, but why and under what conditions? For example, if I were to set the vcore offset to 0.075 and the adaptive to 1.100 for a total of 1.175 volts, what does the initial bump from offset afford me?
Also, what advantages are there with adaptive as opposed to that of just using the offset voltage setting?
Thanks!
0 REPLIES 0
