OC Panel issue QCode 99
SamJazz
Hello Everyone,
First of all I'd like to thank the great work of the community which helped me a lot with some issues regarding some Qcode.
I had an issue that shows an Qcode 98 after each rebooting from the Windows (Win10). after checking many threads, it says to unplug all USB devices and reboot which doesn't change anything, so i decided to chech from the MOBO and i unplugged everything and did a reboot after i plugged eache components.
After plugging everything except the OC Panel, it works amazing 🙂
When finally i plugged the OC Panel, a new bug and this time it shows the QCODE 99, the screen stayed off and all the USB devices off.
Can you help me please 😞
4 REPLIES 4
Chino wrote:
Have you tried clearing the CMOS?
Hello Chino, thank you for the answer.
No i didn't try the CMOS Clearing, I was afraid of having other issues.
I will try it, but what is the most efficiency way to do it ?
hi SamJazz
CMOS Clearing wouldn't affect the device
recommend updating the new version
Use the button at back of the motherboard. 🙂
