No LED lighting on the North Bridge
Lexenz
Hi there,
I noticed that my North Bridge area does not have the LED lighting effect on it. I tried various methods included restart, setting to default on the aura nothing works.... is it possible that my board is spoilt?
5 REPLIES 5
JustinThyme
Is it enabled in the BIOS? Is it plugged into the RGB header on the MOBO?
Yes it is enabled in the bios.
Isn't the RGB header an external portion? Mine is the board itself (PCH)
Chino
Level 15
Lexenz wrote:
Hi there,
What do you mean LED lighting effect? Are you referring to the PCH not lighting up at all or it doesn't function with one of the light effects?
i have the same issue but its with ALL (but the backplate led) that arent on. Yes they are plugged in and yes it is turned on in bios.
