network connection - vlada
anthrax
for whatever reason this forum will not let me reply to your reply about my internet connection. the device manager shows that the intel ethernet connection 1218-v is up to date. i am using a cat 5 cable directly to the router, under other devices there is no driver for the 690lc and no driver for "network controller" I cannot find either anywhere. the cd that came with the motherboard cannot be read for whatever reason. i have the netwok and sharing center open and it intermittently connect to the netwoek sometimes for 5-10 minutes and then sometimes for only seconds. then it goes dead for 5-10 minutes at a time. i have tried disabling and enabling the netowrk controller any other ideas?
14 REPLIES 14
anthrax
running the newest bios 1502
anthrax
figured out how to change the bios. no difference. initial;ly it says network cable unplugged, which of course it is not. If I hadnt already mentioned it, the very same cable works in my old system perfectly, so it isnt the cable
anthrax
i downloaded the file cant figure out how to flash the bios. I rebooted into bios tried to use the ez flash it didnt recognize the file
