Mouse advice
Pleot
Now my G700 Logitech laser mouse is dying 😞 need a new one.
Any advice? Something precise, resistant and not very expensive?
16 REPLIES 16
Pleot
yes I can see one of those in the shop nearby here in the pc, the logitech G402 hyperion fury black, going to have a personal look at the shop tomorrow, its not expensive...
gene-iv-ocz-rev
Pleot ROG GX1000 Laser Gaming Mouse is the best one I ever used. The metal on the top is amazing!!! You can even change the color based on profile without any software installed!
juzz86
I'll vote for either the Gigabyte Aivia Krypton, if you can find it, or the Roccat VPro V900. Both amazing sensors, the Krypton is a bit longer and narrower but has the nicer scroll wheel, the Roccat is a more traditional shape but has a 'mushier' click than the Krypton.
Having had a G700 previously and using it for years, I adapted to the shape of the Krypton after a little time, but the Roccat felt like home straight away. Both a bit lighter than the G700 and not quite as many buttons, but you still get the on-the-fly DPI adjustment and some fancy lights if you're into that.
Good luck!
Hopper64
Level 15
Don't have a lot of experience with different brands but my Asus Gladius works great.
MZ790AE Bios 1703, GSkill F5-8400J4052G24GX2-TR5S, 14900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ HK block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Crucial T705, Windows 11 Pro
Pleot
bThe asus Gladius looks really nice, what kind of pad should I use for it since it is optical?
gene-iv-ocz-rev
Pleot I got the ASUS ROG GM50 Gaming Mouse Pad and it's real nice you can even wash it in the machine it's so strong!
Pleot
Available in the local shop, the other ones would take some days to get, urgent matter, thanks for all your suggestions.
Hopper64
Level 15
Using an EVGA mouse pad. I believe it's the only one at their website.
