Micro Stuttering from running a balanced power plan! (TEMP FIX HERE)
LiveOrDie
Level 11
There seem to be a problem with x99 and using a balanced power plan it produces Micro Stutters in some games i can't say how many games get this problem but Bioshock Infinite is one of them, After comparing both balanced and High Performance you can clearly see the problem, And seeing my 3770K runs a balanced power plan fine with no stuttering i can only put it down to the chipset?
Games Affected/Tested so far
Bioshock Infinite
Borderlands 2
Borderlands The Pre-Sequel
EDIT 03/02/15 TEMP FIX
This problem seems to be related to the unreal engine and X99 chipset there is no hard fix for this problem but you can download this handy tray program called Full Throttle Override
and add all unreal engine games to its games list this will set a High Performance power plan when starting the game.
48 REPLIES 48
LiveOrDie wrote:
Yer I'll be doing most tests when I'm home like I said only some games have this problem lm not sure if its related to the board or the chipset, I don't get this problem in dead space 3, titan fall or BF4 seems to be games on the unreal engine but can't say for sure until I test more.
If you run something like Unigine valley, can you see a difference in runtime benchmark between balanced and performance plans? I do not (and neither do I see the micro stutter yet). I am just wondering if you can identify the difference in benchmarking. Micro-stutter is still a drop in FPS albeit fractional...but over a benchmark run it should show-up.
LiveOrDie
Level 11
EDIT:
OK after doing some test here what i have
Single GPU on Balance Power Plan = Bad stuttering
Single GPU on High Performance Power Plan = No stuttering
SLI GPU on Balance Power Plan = Bad stuttering
SLI GPU on High Performance Power Plan = Reduced Stuttering but is still there
LiveOrDie wrote:
EDIT:
Hey!
On what was this tested ? And btw SLi and Xfire aren't the most reliable sources in stutter free application.
Do you experience stutter in a previous chipset with SLi in the same test ?
Thanks
Max
Cpu : Intel 5930K@4.25ghz@1.2v / Cache @4.25ghz@1.20v
Cpu Cooler : Corsair H100i
Case : Corsair 780T
Memory : G.Skills 32GB DDR4-3200mhz CAS 15-15-15-35-1T@1.370v
Motherboard : Asus Rampage V Extreme (BIOS 3504)
M2 : Samsung 950 Pro NVME 512gb (Gaming)
M2 : SSD1 : OCZ RD400A 128gb (windows)
SSD1 : Crucial MX100 512gb (data)
Gfx : EVGA Titan X w/ 980 Hybrid Cooling AiO Liquid Cooler
PSU : Antec HCP-1000W
Monitor : Asus RoG Swift
Avenger411 wrote:
Hey!
Thanks
Max
Bioshock infinite Benchmark just clearly watching it run i can see the stuttering, Watching the bench run using 1 GPU it runs smooth no stutter as long as I'm on High Performance for SLI i can't say i brought the 2nd GPU when i got my R5E but i seem to only get these problem in games using the unreal engine as I've played BF4 for hours, Ill run some more tests later on and see how it goes i know i was getting stuttering in SON OF ROME as well i will test this game to and report back.
Hey!
Have you tried Unigine Heaven 4.0? If so, if stutter is present, we could all batch test with a bunch of different computers so it could help pinpoint the problem if it's hardware related or chipset drivers etc.. If you haven't done it yet , could you? I will test it too if you report it has stuttering!
Thanks
Max
Case : Corsair 780T
Avenger411 wrote:
Hey!
Thanks
Max
Ill run it tomorrow when i get off work @ 1080p max settings.
Hey
Alright then! I'll wait for your input and ill test it if yours comes back positive.
Thanks
Max
Case : Corsair 780T
Azusa
Doesn't look to be a universal problem. These results were run @ 1920x1200, default Unigine Heaven 4 settings.
Balanced High Performance
FPS 46.3 47.2
Score 1168 1190
Min FPS 20.8 8.1
Max FPS 109.2 112.0
I also tested using the Shadow of Mordor benchmark, since that game (still) doesn't support CrossFire; results between balanced and High were basically identical.
FPS 46.3 47.2
Score 1168 1190
Min FPS 20.8 8.1
Max FPS 109.2 112.0
Hey azusa!
Stuttering doesn't always present itself as performance loss. So comparison between balanced and high perf is somewhat useless imo. Although, did you watch both videos all the way ? if so, could you notice stutter ?
thanks
Max
Case : Corsair 780T
Azusa
I did, and didn't notice any difference. Which isn't to say I don't have plenty of stuttering, it's terrible in Wolfenstein: The New Order, just doesn't seem to make any difference what power saving mode I'm in.
I ran the tests because I've noticed stuttering is significantly worse on this platform, than it was with the same GFX card on an old X38/Q6600 system. *Something* is wrong, but in my case I don't think it's power saving related.
