Lamptron Fan Controller
Hopper64
Level 15
I have Lamptron's FC5v3 controller, but I can't find whether I can run 2 fans with a splitter cable off one channel. Tried emailing support with no success. Anyone know? Thanks.
MZ790A Bios 2002, GSkill F5-8000J3848H16GX2-TZRK, 13900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ Optimus block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Samsung 990, Windows 11 Pro
Nate152
Hello Hopper
Yes you can do it, the FC5-V3 is 30w per channel, you could run ten 120mm fans off one channel if you wanted to.
Hopper64
Level 15
Oh, thanks Nate. Appreciate the help.
