Huge problem with my motherboard !!!
jacksaj
Hi guys!!!
I bought my motherboard Asus Rampage V Extreme in December 2014 and this motherboard fail after 11 months :(. I create RMA case and I send to asus for service, after two weeks they send to me new (refurbished) motherboard, and now I have big problem with this mobo. When computer is cold after night I have to start computer twice, first time mobo post with the asus logo, after that windows logo post and than computer shuts off like no power, than I have to start again and second time everything is ok, but to boot to windows I have to turn on "slow mode" and "LN2" must be enabled, with my old motherboard slow mode and LN2 mode was always off and disabled and I didn't have problems to start computer or boot to windows at all. In the bios which I upgrade to the latest 1701 (they send motherboard with old BIOS - 0603) I setup everything like was it before with my first motherboard. Another thing bothers me in the BIOS where is GPU Post tab this line showing no vga card in slot how come? Before was everything ok GPU Post show NVIDIA Geforce card or something like this. Once I turn off slow mode or disable LN2 mode, computer doesn't boots to windows, just asus logo post and after that black screen, and VGA led light is solid red with the qcode 95, sometimes with diffreant qcode like b2, b6 all kinds of qcode. To start windows I have to clear BIOS with the clear bios button and resetup everything again but after this (clear BIOS button) is so hard to get in to the BIOS. So I don't know if im doing something wrong or this new (refurbished) motherboard is some how broken, because is working but weird way not like the brand new one I bought year ago. After resseting the BIOS computer doesn't even boot to the windows. I have to always turn on slow mode and LN2 mode must be enabled. Can somebody help me? Any idea what to do? RMA the motherboard again? Im so mad that $470 mobo is so hard to work with. I read a lot of forum threads and I know a lot of ppl have same or similar problems with this motherboards. I have 32 of RAM (Corsair), Geforce GTX 980, Core i7 5620.
7 REPLIES 7
Chino
Level 15
Leave Slow Mode and LN2 mode off as por default. Clear your CMOS. Then try booting with only one memory module in the DIMM_A1 slot.
jacksaj
Thx Chino for help. I tweak my BIOS and now everything working good, sometimes only first thing at the morning i have to turn on computer twice, first time computer shuts off before windows starts, but second time computer starting with no problems and working all day long good, any idea how to fix this?
Chino
Level 15
jacksaj
Hmm, two kits of RAM? yeah i have 32GB 8x4, but same brand everything is the same timings, speed. I assume i have 8 slots so i can have 8x4GB of RAM with no problems. So any idea how to setup this memory in BIOS to change start problems? Now i have XMP mode enabled, RAM is running with 3000Mhz speed, voltage is 1.32.
Korth
Level 14
I also use two exactly identical 4x8GB DDR4 kits I purchased together, they even have adjacent serial numbers.
Here's Raja's infamous Don't combine memory kits! thread. Short version: DDR4 kits are designed (and binned) to work as a unit, they can't even be combined with other identical memory kit(s) without throwing all their fine timings and voltages out of whack. I've learned that "identical" DDR4 kits can each have wildly different tertiary timings, the memory factory programs dozens and dozens of settings into the SPD which an end-user simply cannot improve any further.
I offer a lengthy explanation of how Haswell-E iMCs work here. I was never really able to get my 32GB DDR4-3000 kits to work well with my i7-5960X proc, I wasted a *lot* of time tweaking and retweaking yet never got it to run stable (let alone to run fast) for long, in hindsight I almost wish I'd just bought a single 32GB or 64GB kit. My E5-1680-3 proc runs at a flat 4.4GHz ("Turbo Boost always ON" = Enabled, lol) and addresses all 64GB of DDR4 at full-rated 1500MHz/3000MTps speeds.
Korth wrote:
While my old i7-5960X processor was capable of a ~1.3V 4.5GHz overclock (on air), it would only do so with one of my DDR4 kits running at 2133 16-18-18-36. XMP was useless.
At stock 3.0-3.5GHz, I could get one DDR4 kit to run at 2866 14-15-15-35, or both kits together to run together at 2133 17-18-18-36.
It turns out my i7 was a mixed bag: a fairly decent overclocker, a pathetic iMC.
Following advice from online guides like this one, I "burned and binned" my 8 DDR4 DIMMs. I found 5 were superior, 1 was decidedly average, 2 (one from each kit) were underspec weaklings - more or less typical results for these kits. Dropping the two loser sticks out allowed me to OC my proc to around 4GHz and still run the other 48GB at rated 3000 15-15-15-35. Much time wasted testing and tweaking and fiddling of voltages.
I later traded my i7 for a similar E5 proc. The guy who got the i7 brags that it runs 4.7GHz (on water) with 4x4GB DDR4-3333 at full spec. The E5 I got can achieve a modest overclock but has a powerful iMC which happily blasts all 64GB of my DDR4 at full spec - basic XMP, no tweaks, no fiddles.
So - for my particular parts, anyhow - the processor determines all. A strong iMC in the proc can even handle borderline memory sticks. A weak iMC in the proc will make it near impossible to run a single high-frequency kit at rated speeds.
[/Korth]
jacksaj
Alright guys, so looks like i have to live with that like it is :(, but anyway it is weird that we have 8 slots for memory and we can use only 4 slots, because 8 exactly identical sticks not gonna work. By the way they working perfect when they not overclocked to 3000Mhz, so stock clock 2133 is ok for 8 sticks, but 8 sticks overclocked to 3000Mhz not. No offense guys 🙂 and thank you again for help !!!.
