10-23-2015
05:41 AM
- last edited on
03-06-2024
09:03 PM
by
ROGBot
10-23-2015 07:31 AM
10-23-2015 07:43 AM
MP7 wrote:
So I have my speakers plugged in the green(line in) and anyway when you click on it it asks you what did you plug in or what do you want to set it to (right window in screenshot below), and the speakers work just fine then.
If I set this to headphones and really connect the headphones there they work, but then I cant connect my speakers(simple stereo speakers) anywhere else because on all other jacks it doesnt ask me what did I just plug in.
So yes after I plug in the speakers on any jack, in the software the jack lights up but when you click on it nothing happens.
10-23-2015 07:55 AM
Chino wrote:
From what I understand after reading your post, you're trying to connect your headphones and speakers at the same time to the motherboard. But you're not using the front panel connectors.
So my question is this. If you're connecting your headphone to the read green port, where are you connecting your speakers?
10-24-2015 03:36 PM
07-31-2016 09:31 AM
07-31-2016 11:11 AM
MP7 wrote:
https://rog.asus.com/forum/showthread.php?76324-headphones-and-speakers-working-in-same-time-X99
So it seems it's confirmed, for people not using the front audio ports it's impossible to have speakers and headphones on rear ports. Unbelievable!
No other choice but to buy new speakers that have a rear connector for headphones, the ones I have right now have it at the front and I don't want it to be visible when it's connected.
Or another option is buying wireless headphones.
02-18-2018 01:57 PM
01-02-2019 08:17 AM
DarkTech wrote:
Well I have the same problem as the main subject, I even have my front audio connectors connected, I am using ASUS ROG STRIX B350-F Gaming. My 2.1 Speaker system is connected to rear green jack and when I connect my headphone and mic jacks on the front It accepts that too but don't give and option to select one of them as default one so I can just select my output and go and because of this I always need to plug-in and out my headphones and mic everytime I want to use them. I guess That's why GIGABYTE and MSI are holding first and second place respectivly in the world in sales.
