help with temperature
Bellaziciao
Good morning everybody, I have a problem with my pc, recently my workstation started to overheat in idle, as now, with 45 °C !
I've already resetted my cmos to default, but the problem persist!
My configuration:
BIOS -> default 2101
CPU-> i7-5820k
GPU-> strix 960 4gB
cooler-> corsair h100i gtx
PSU-> corsair rm750
ram-> ripjsaws4 F4-3000C15Q-32GRBB
Already tried to switch every bios from 2001 to 3501
Thanks for the support!
PS. i've connected my liquid cooler pump directly to molex with an adaptor becouse of corsair link 4 problem on windows 10
13 REPLIES 13
Zka17
Level 16
Not sure why did you reflash the BIOS for a temperature problem... how where/are the voltages?
I would have first check the cooler... connect the fans directly to the PSU, see if the temps are coming down...
Check the CPU block if it is still securely attached...
on the cooler everything seems ok, i checked the plate, and the radiator, all ok
Nothing more to check, no-one have the same cooler?
Bellaziciao
this is 2 screen of hwmon
the configuration is:
the cooler punt directly on the psu at max power I suppose!
the controller of the pump, a usb2.0, is detached from the modo, and the software unistalled, becouse otherwise, in the boot the temperature reach 70+°C
the fun for the cooler are connected on the motherboard and set to max, with no effort on the temperature
63297
63298
Zka17
Level 16
Mate, your Vcore is waaay too high!!! You need to go in BIOS and double-check it...
high voltage = high temperature
It is better to set it manually in BIOS... if it is on Auto, for some reason may spike...
Any suggestion on the right voltage for the vcore ?
Zka17
Level 16
Could you, please, share the exact info about your motherboard and CPU?
You said that your CPU is 8520K - but those where not produced yet by Intel, not sure about AMD either... is it a 5820K?
Also, if you go in BIOS, the Vcore is also 1.8V there?
And, are you using any OC'ing software from OS (like AiSuite)?
yess, it's 5820k, not 8520k!
this is a new screenshot from hwinfo
63315
and this from cpu-z
63316
Zka17
Level 16
And here is the guide for Haswell-E OC'ing: https://rog.asus.com/forum/showthread.php?51063-The-Haswell-E-Overclocking-Thread-and-Overclocking-G...
(well, if your CPU is a Haswell-E)...
Bellaziciao
it's not just for overclocking, i was able 1 months ago, to do 4,5 core/4,2 cache @ 1, 28v, full load @60°C, now at stock, i cant have less than 43°C!
What could be?
