Help with BIOS error
samarlian
So i flashed my bios on wednesday from 2101 to 3101
The problem i have is once pc is shutdown and powered off at the wall. When i turn it back on it goes to dos screen and says
Bios is updating
do not shutdown or reset the system to prevent system boot failure ... it then reboots 3-4 times saying this and then reboots saying
Please enter set up to recover bios
When raid configuration was built, ensure to set sata configuration to Raid mode.
Press F1 to run set up.
Once i have pressed F1 and entered bios then hit F10 the pc boots back into windows.
The usb stick with the R5E.CAP has been removed from the pc incase you think it was left in the rear and keeps trhying to install.
If i dont power it off at the wall the pc boots normal any ideas ???
Thanks in advance
Samarlian
21 REPLIES 21
drop4205
Level 12
Try reflashing the bios a second time
Strix X870e-e / AMD 9800x3d / Gskill 32gb 6000 / Crucial T705 / ASUS Prime 9070 XT / Lian Li 011 compact / Lian Li Hydroshift AIO / Lian Li Platinum 1300 psu / Windows 11 24h2
its like 18 months old , the battery is fine but did put another new one in to rule it out
then after that 3-4 reboot step cycles it then does this asking to recover the bios
57664
samarlian
it wont let me install it again, so iam going to flash it back first
FireRx
Level 11
Samarlian, how old is you board, Do you have the means to test you battery on the board? Just curious
Intel Core i9 103900KS
Asus Maximus Z790 Extreme [bios 2801]
LG (34U97-s) Monitor 3440 x1440
Nvidia RTX 3090 FE
Windows 11 Pro
64gbz Memory
samarlian
here is a picture of what it does after a boot up after the plug in the wall has been powered off 57663
samarlian
I did a bios flash back to 3009 and then re flashed 3101 but still the same after a cold boot from the pc been powered down from the wall as per pics above
So looks like i will have to leave the motherboard on standbye all the time and not turn off at the mains.
Can any one else see if they get this problem
and why is it mentioning Raid as i have never used Raid on this board ????
samarlian
Can anuone help ??
drop4205
Level 12
Pull board from case and place on cardboard. Have cpu, cpu cooler, gpu, one stick of ram and hatddrive and see if it works to rule out short or bending of board in case. You have another psu to try? Any codes it stops on?
