FYI: PS4 (pro) controller + PC = Boot process stuck on "Q-Code 61"
Axle_Grease
BIOS 3801.
The boot process never gets past q-code 61 irrespective of the USB port used by the controller.
(update) I also plugged the controller in a mate's Rampage V Extreme 10 mobo. Same thing. However, it's an OS problem though. The boot process manages to get past q-code 61 when the controller is disabled in Device Manager.
"Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes." -- Unknown
0 REPLIES 0
