EDITION 10 Strange USB issue
Deceiver
I noticed when i playing game - quake2. when i install realtek sound driver and his come's with sonic studio - my rear usb port working bad with mouse that has poling rate 1000hz. - when i move the mouse i noticed microfreezes about 0.5 sec long.. when i use 125hz mouse poling rate - this dosnt happen.
i try diffrent mouses logitech, razer, steelseries - rusults are the same. This never happen on this system with another x99 board's - have about 5.
When i uninstall realtek sound driver - all works fine.
Try another OS, video driver - still the same.
7 REPLIES 7
Chino wrote:
Are you using the latest version from the support page?
yes the latest.
Is rear usb ports sharing bandwich with gpu pci e lanes?
https://www.youtube.com/watch?v=xbZxzsSQBDI here is vid about this issue - DO NOT WATCH IN FULL SCREEN MODE.
this showssomething like my camera turn around on 180 degrees or any side when it happens.. or i kick back to my place where i just was been.
on the end of first part where i quit game - you can see my camera turn down at the floor - bud i play quake 6 years and i can control my movement brilliant !
Chino
Level 15
Can you try using the Realtek driver from the Realtek website instead? That one doesn't come with Sonic Studio. See if the problem persists.
So i try realtek from web site, problem is gone but not completely.. sometimes i had some kind of lag - but not as before - it feels like i play on 40-60 + ms input lag monitor - like S-PVA..
And my mouse feels sluggish and not so responsive as on previsious motherboard even in windows, my previsious mobo was - DELUXE II.
Before this i use msi and giga and i do not have such a problem((
I have another one RAMPAGE 10 - but from 100+km from me) it's boring to road and take it back to reassembly system to find out what is causing this issue..
Maybe owners can reply if someone has this issue..?
Chino
Level 15
If you're experiencing this problem with the Realtek driver as well, it's say to safe that the problem isn't the Sonic Studio driver. Most probably it's a compatibility issue between your game and the Realtek audio driver on a whole.
So today i try another mobo and it did the same when sonic studio installed..
Now i find another trouble - and have question.. when i put in socket my CPU and then close the socket - i heard crackling noise - but everething runs, fine.. on another board this thing does not happen - Can it be bent socket tray ? and did amount of pressure on the CPU ? i inspect socket and pins and other things seems fine..
I see it cuz another mobo did not do that) any help ??
Chino
Level 15
