CPU Over Voltage error! HELP R5E 5820k
smokeintheeye
Level 11
Hello can someone help me out please. i have a rampage V extreme 3.1vr with an i7 5820k and 16gb ram corsair vengeance lpx. the PC has just been running the last 3 days as iv just finished my new build. all the bios setting are on stock safe default(not even XMP on yet). but iv just started it up and got a CPU OVER VOLT ERROR!!! on startup into windows 10. why am i getting an over volt error on safe settings? will my CPU still be ok? its not even a week old yet' if someone can tell me the safe setting to use for the i7 5820k please it will be a big help as i dont want to see that error ever again. thank you
Any Reputation is welcome. thanks
31 REPLIES 31
Qwinn
Level 11
As I mentioned on another thread or two, you can get some odd behavior if you've plugged too many things into one power strip. That specific error was among the issues I experienced. If you have a lot of things plugged into the same power strip as your computer, try moving a few of them off and see if it helps.
smokeintheeye
Level 11
Hi Qwinn thanks for the reply. the computer is not plugged into anything but the wall. im using a corsair HX1000i psu. there is no overclock running not even XMP and the mobo come with bios 1701. got the error after a restart now i dont feel like i want to risk truing it off or on. the mobo is not even a week old and now i have no trust in it.
Qwinn
Level 11
Hmm, what video cards do you have? With what you've given so far, I don't see anything that would even come close to taxing a 1000W PSU.
The one thing you can still take away from my experience, though, is that it seems you can get the "Overvolt" error even when it's actually an undervolt/brownout. Which is hopefully the case for you as well, as that would be much less likely to do any lasting damage.
Avenger411
Hey,
Try setting a manual voltage in bios.
Max
Cpu : Intel 5930K@4.25ghz@1.2v / Cache @4.25ghz@1.20v
Cpu Cooler : Corsair H100i
Case : Corsair 780T
Memory : G.Skills 32GB DDR4-3200mhz CAS 15-15-15-35-1T@1.370v
Motherboard : Asus Rampage V Extreme (BIOS 3504)
M2 : Samsung 950 Pro NVME 512gb (Gaming)
M2 : SSD1 : OCZ RD400A 128gb (windows)
SSD1 : Crucial MX100 512gb (data)
Gfx : EVGA Titan X w/ 980 Hybrid Cooling AiO Liquid Cooler
PSU : Antec HCP-1000W
Monitor : Asus RoG Swift
lordo59
Everytime I read someone's not using a UPS part of me dies inside.
Avenger411
Hey,
I feel you lordo. Some spend 3-4-5k and plug the damn computer in the wall outlet. Jesus.. Talk about playing with fire :).
Max
Case : Corsair 780T
smokeintheeye
Level 11
It has a MSI R9 290-4G gaming gpu overclocked from 977/1250 to 1100/1375. pc was plugged into a surge protector. but i was tolled that it can give wrong readings and make the pc unstable? is it better plugging it back into one? anyone know of a very good UPS one i can use? its just that my rampage iv mobo died on me 3 weeks ago. but i cant get a x79 mobo anywhere from in the uk. so i had sell the cpu and ram cheap and fork out on a full new pc. i was gutted as my old 3930k was an amazing overclocker vcore 1.42 got me 5ghz for benchmarks offset of +0.15 got me 4.6ghz for 24/7 use. not even got round to overclocking this one yet. now i dont even know if i want to take the risk. do Intel still offer insurance for cpu? thank you all for your help.
ps. if i get a UPS will i need one the same watt as the psu. just i have never used an Uninterruptible Power Supply as i thought they were just for power cuts so you had time to save any work your doing in time.
GoNz0-
I use one of these http://www.apc.com/shop/gb/en/products/APC-Smart-UPS-2200VA-LCD-230V/P-SMT2200I
It runs all my computer gear with ease, some say overkill but with a quieter fan it's great.
It used to be hardwired into the office, it also ran the combi boiler in case we needed to shower with no electric in the morning but now it is my sons room so it sits net to the PC instead of the loft.
Qwinn
Level 11
I've considered getting a ups, but 900 watts is about the biggest one I can find advertised, and I'm unsure if that would be enough for a system with a 1200w PSU.
