02-23-2015 07:53 PM - last edited on 03-06-2024 03:30 AM by ROGBot
02-23-2015 08:08 PM
02-23-2015 08:38 PM
02-23-2015 09:15 PM
02-23-2015 09:20 PM
02-24-2015 11:14 AM
Radeson wrote:
Yup Yup... Thanks Chino. Im Thinking of running two of these pumps off of two separate headers bc it says 0.3-1.5 amps and it is rated all the way to 24 volts. so i think at 12 volts it sholdn't get to more than 0.9 amps. What do you think?? I dont think the motherboard headers can even push more than 12 volts. So the 1.5amp rating on the pump has to be only for when it is throttled to 24v.
http://koolance.com/pmp-450-pump-id-13mm-1-2in
02-23-2015 09:42 PM
02-24-2015 05:05 PM
Chino wrote:
That pump runs off the Molex connector actually. The single blue wire is for PWM control. 😉
02-24-2015 02:04 AM
