Bluetooth not working on Rampage V Edition 10
therealstevezis
I've tried updating the driver software, installing and reinstalling:
Bluetooth Driver Package V12.0.1.650 (DriverVersion 12.0.1.653) for Windows 10 64bit.(WHQL)
to no avail. The strange thing is that the Bluetooth can sometimes detect a device, but it pops up as Unknown and is unable to ever pair with the device.
Has anyone experienced a similar problem, or have any suggested fixes?
26 REPLIES 26
Brighttail
Level 11
I downloaded it. Won't hurt to try it I suppose.
Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
Brighttail
Level 11
No issues with new BIOS so far. Bluetooth still not working.
this is so bad!
i have logitech mx master mouse with usb dongle when copy file to flash disk mouse hang and dont work smoothly and Bluetooth install but cant find any device!
enyceedanny
You do have the wifi antenna connected to the board right? I don't use wifi so I never plugged it in, but after finding out that my bluetooth wasn't working, I plugged in the antenna and it works fine.
Your rampage v10 bluetooth work fine?find bluetooth device and connect to them?i plugged my wifi antenna.wich driver version and windows you have install?
Yes, my bluetooth works fine. I use it quite often to connect my PS4 controller. I'm on windows 10 x64 Pro with all latest updates. And I'm using the drivers directly from the RVE10 Support page on the site.61827
you use onboard blutooth on rampage v10 or USB-BT400 ?
Onboard bluetooth. I don't own any bluetooth dongles..
you are so lucky 🙂
Also works with the older drivers as well.
61842
