What error message is coming with the blue screen? That's a huge part of diagnosis. Could be software related and you'll spend forever chasing your tail trying to disable hardware.
Dont make the mistake of assuming all problems are related to the same issue. Maybe, maybe not. In your case Id highly doubt any of its related and you are looking at 3 different issues.
The power thing is common and everyone seems to push back when I give them the answer that fixes this 99% of the time saying but I didnt change that.
Go to control panel>hardware and sound>power options>balanced>change plan settings>change advanced power settings>restore plan defaults>OK>done
Something else that causes this issue is fast joke.......uh I meant fast boot......no really I mean fast joke because if you use it the joke is on you. Disbale that crap.
On the power options page in the left pane "choose what the power buttons do">change setting that are currently not available>uncheck fast start up> save changes.
Problem with fast boot is its hibernation renamed, plain and simple. It dumps the kernel and drivers that are loaded in ram in the exact state they are to hiberfil.sys file on your drive then reloads the same file on reboot. Problem is if there is any issue when you shut down it reloads the problem and you h
